IR led code
Can you please add an IR send block in mBlock?
The idea is that we are going to use the mBots on a track where participants have to eliminate (Arduino) targets by sending IR commands to these targets in the right order. The codes can be the same as the current remote control, as each target will react to another code. If the target is hit, it will beep or blink leds until it is reset.
