How to: Voice Controlled mBot
Hi, I’m fairly new to programming the mBot to do things. I have a few questions.
  1. is it possible to upload a program to run when you press “D” for example on the IR remote, but keep the rest of the factory settings… So I don’t need to re-load the firmware to get it back after each time I try to run a custom built program?
  2. I’m trying to re-create the ‘Voice controlled mbot’ program that came on one of the cards. At the ‘if…’ command, I can’t figure out how to get the ‘loudness’ object from the sprites area into my blocks code area. Please help!
Thanks,
Jon
@Jon-Uma
  1. Not possible, as far as I know :frowning:
  2. The code will work differently than you think. :slight_smile: Here is an example:
    In mBot, add the Upload Mode Broadcast extension:
Make a simple code like this and upload it:
Now, in your Sprite, add the same extension (Upload Mode Broadcast), and make this code:
The mBot will now move whenever you make noise, although you should note that the mBot needs to be connected (via Bluetooth or cable) for this to work.
The mBot software doesnt have speech recognition. So, if you code that, you could just scream.
Are you saying that if you manage to code a speech recognizing mBot, you should scream in joy; or that you can’t code one, so just write a code so that the robot does things when you scream? :joy:
Lol! You cant code it to recognise words, so yeah​:rofl::rofl:
