6mm motor shaft connector please!
Hi!
I would like to know if its possible to make shaft connectors compatible with 6mm diameter shafts, not just 4mm.
I have various spare 37 motors that fit perfectly in Makeblock’s mounts but the only problem is that the only thing I can do with them is use them as wheels (with Pololu wheels, not makeblocks) since Makeblock shaft connector is only 4mm.
Or at least distribute officially a shaft adapter/coupler ?
If its not possible, then what alternative could I use to connect these motors to makeblock M4 holes ?
Thanks
