I have the similar problem to
Changing the battery or using the USB cable DID NOT work for me.
I am using mBlock for MAC in my class. some students have problem locating the bluetooth of the mBot Ranger
This does indeed sound like the same problem I had with my LED’s. Eventually, I ended up making a small recording with my phone and sending that in with a support request. Based on that, they had me send everything back under warranty. All in all, this was a good solution, since my new board works like a charm.
mBlock 5 had a lot of limitation. You will not able to complete the task in the ebook if you use mblock 5. My advise is to stick to mBlock 3 if you are teaching this unit.
Thank you for your suggestion, we will keep forwarding to the software team. Very appreciate that.
