My XY plotter appears to work fine. If I use benbox, I can turn the laser on and use it although the motors wont move. If I use mDraw, the motors work and the machine works perfectly, except the laser wont turn on. Help??
XY Plotter Issues
XW_makeblock
Hi, could you swap the laser red and black wire in the order of black red while using Benbox? The setting of Benbox and mDraw is different. Let me know if it helps.
