Upgrade firmware not working
Hi, I try to connect my mBot Ranger with USB cable, but when I go to “Connect” menu, I can’t see it on the “Serial Port” menu. So I activate Bluetooth on PC (MacBook) and than I can see and connect to the “/dev/tty.Makeblook-ELETSPP” on the “serial port” menu. I selected “Upgrade Firmware” but after a while a massage “upload failed” appears. I’m using mBlock (v3.4.8). Thanks in advance for your help!
Hello! I have a problem with uploading to arduino… Please help!!! This is what happens when I try to upload my program to my mbot:
My mbot is starts running immediately although I typed in program to "wait until button pressed"
Please helpp!
First off, neither Bluetooth nor the WiFi dongle have access to the onboard programmer so you cannot upload programs, firmware, etc. through that path.
Next, you will need to install a different serial driver because Apple changed the USB stack and broke the old workarounds. See this thread.
Thank a lot: it worked fine!
