Ultrasonic sensor
Please see “Challenge” in the bottom of webpage http://learn.makeblock.com/en/robot-kits/mbot/the-ultrasonic-sensor/
Can you put the code above together to make the completed program?
I don’t know what I should do for completing program.
Who can advise? Thank you.
I believe you are being asked to write the program in mBlock using the example code. Remember that Scratch programs require a hat block (such as when [green flag] clicked]) to execute within mBlock.
Thank you, Sir,
I made 3rd coding with 1st and 2nd code. On testing this, it is not bad.
One more question, how to rotate KIT 90 degrees exactly to the left / right ?
According to mBot Tutorials,
robot wasn’t turning enough when it encountered an object, so I added a wait (1 sec) command after the turn.
When we code, we have to adjust waiting time ???
Hi funrobot,
Yes, you need adjust the waiting time if you want to make the physical robot turn a certain angle.
The motors on the mBot do not have encoders, so as @tec_support mentioned all movement is based on time.
