Hi @tec_support,
Thank you for your support.
If i may, i’d still like to know what’s the difference between the two options: Speed / Power
The Arduino code for the Speed-rpm block adds PID related parametres.
Encoder_1.setPulse(8);
Encoder_1.setRatio(46.67);
Encoder_1.setPosPid(1.8,0,1.2);
Encoder_1.setSpeedPid(0.18,0,0);
Can i assume that:
- Power = simple pwd/duty cycle (would this be like a simple DC motor (no Optical Encoder)?
- Speed = PID (~feedback…) for pwd
Is the PID thing the whole reason why the motors are Optical Encoder motors? So that they can allow accurate repeatable motion control?
Sorry if it sounds like i have no idea of what i’m talking about … it’s close enough
void setup(){
//Set Pwm frequency to 8KHz
TCCR1A = _BV(WGM10);
TCCR1B = _BV(CS11) | _BV(WGM12);
TCCR2A = _BV(WGM21) | _BV(WGM20);
TCCR2B = _BV(CS21);
// Pre-defined parametres, no manual control ***
// Set encoder motor Port1 === POWER block
attachInterrupt(Encoder_1.getIntNum(), isr_process_encoder1, RISING);
// Set encoder motor Port1 to === SPEED-RPM block --> PID
// User values ***
// Set encoder motor Port1 to === SPEED 180 RPM --> PID
Encoder_1.runSpeed(180);
// Set encoder motor Port1 to === POWER to 100 (PWM)
Encoder_1.setTarPWM(100);
// Set encoder motor Port1 to === Rotate 1000 degrees at SPEED 180 RPM --> PID
Encoder_1.move(1000,abs(180));
// Set encoder motor Port1 to === POWER to 0 = STOP (PWM)
Encoder_1.setTarPWM(0);
Thank you.
Stefan
