Hi Makeblock,
I have been using the Neuron app from the beginning and it is getting better.
I would like to see in future versions, an application for the use of several students:
- Possibility to create directories for the organization;
- Possibility to import / explore projects or parts of programs;
- Possibility to work on same program from multiple devices at the same time (with the black boxes);;
- Possibility to have groupings (black box);
I propose : Black box
The application works well when the program is simple.
However, when there is a lot of instruction, it quickly becomes like spaghetti.
The own a new instruction to group a set of code.
- Normal black box
- Secure black box (so that the student does not see the solution)
Principle is simple. Several input values and one output value. When double-clicking on the black box, it opens a blank page to add a set of instructions. The clarity of the code will only be better. It is also necessary to add a label to the black box to indicate what made or which student is responsible for this part.
Example of a project that I wanted to make even more complex but spaguetti code stop me: TNT
