Stable mount of a vertical motion guide beam on a turning plate
Hello, I wonder if somebody have an example how to build a stable Makeblock assembly of a linear motion guide 500mm in a vertical position fixed on a turning table (of pulley). I have a project to start a rotating positioner assembly of two movements. 1: an up/down guide +/-400 mm movement with step motor and 2: a rotating movement with step motor in order to distribute a metal piece (max 500g of load) at 4 positions around the vertical axis.
Like this. Thanks in advance for your ideas and help.
