Speaker Extension
The animal sound and the transportation sound do not work in the speak extension. Other sounds work just fine.
This is for the mBuild speaker on halo-code I am assumning?
The speaker in the AI & IoT Creator Add-on Pack for HaloCode & CyberPi pack.
Click the block. What value does it return in live mode? You may have to re upload files to the speaker.
@HTH
Check out the docs here:
https://education.makeblock.com/help/mbuild-speaker/
And the preset files here:
https://drive.google.com/file/d/1KYHwA1lFkHikfR4ZFNuW-GDsRN1qnXnP/view
The iNodes for the file system are at 100%. So you cannot add the files to the storage unit.
It has 16gb of space on it. Have you used it all? @HTH
You cannot use the space if the iNodes are at max. I know I have plenty of space but for some reason the disk file system iNodes are at max.
I am considering reformatting the storage unit.
What do you mean by iNodes? As far as I am aware, the device is not in that format…
You can format the device and re-upload the default files from this URL:
The supported file format is mp3 by the way.
