Red lights on boards of XY Plotter which does not work
I 've finished the assembly of the XY plotter and checked the wiring. I’ve got a Mac Book Air with MDraw 1.2.2 installed. I’ve installed CH34x_Install_V1.3 too. The arduino board is an Orion. The XY plotter doesn’t work and all the lights are red: what can I do?
Did you select the port and update the firmware?If you did the motors should be holding their position and you won’t be able to move them by hand when the board is powered on.
mDraw took time te be selected on XYplotter. I loaded on more time mdraw (the last version for mac) and now it’s better. Thanks very much
