I am trying to run the example of the MeGyro sensor on Makeblock Orion board.
I use the arduino IDE 1.6.7 and the last version of the Makeblock library from github and the other examples work fine.
I only plugged the Gyro sensor on the board and run the MeGyroTest, but it does not output anything.
I tried to debug it by adding log messages and it stops in “MeGyro::begin()”.
When it execute the first “writeReg(0x6b, 0x00)” it stops at “Wire.endTransmission(true)”.
I also tried the I2CScanTest and it also hangs at the first Wire endTransmission() call.
Is it a problem with the arduino version? or is there something else I could check?
Thanks for your help!
Regards.
