Problem with port 2
Hi, just received and build mbot 101 for my son. Successfully connect via bluetooth but found that only one wheel is working. After couple of troubleshooting steps I found that the red port numbered 2 seems to be faulty. Both wheels turn individually when I plug them into port 9 but if I try port 2, nothing works. Is it safe to say the port is faulty or am I missing sonething?
Trouble with Mbot motor port programming
Hi Jaco,
If you connect the mBot 101 to the mBlock with USB cable and run following program, will both the motors work?
If the motor connected to Port 2 still not work, please connect this motor to Port 10, then run the following program and check if both motors work:
Thank you for prompt respons, will try today and revert.
