"Power: 3.7V Lithium battery(charger on board) or four 1.5V AA batteries (not included)"
The title of this topic is the original description in this website ( http://store.makeblock.com/mbot-v1-1-stem-educational-robot-kit ).
I’ d like to clarify what does that topic mean in details?
I am trying to understand how and if the I can recharge the power ?
(does charger on board work like for mobile phones)? does the mbot get the power from the pc -through the usb cable?- for example when I run the code multiple times for trial purposes?
Is there any difference between bluethoot and 2.4G regarding this topic?
Thanks
The 3.7V lithium battery is connected to the white terminal on mCore directly, and then you could use the USB cable to connect the mCore to PC, which allows the lithium battery charging automatically.
Regarding your last question of “Is there any difference between bluethoot and 2.4G regarding this topic”, there is no difference to recharge the 3.7V lithium battery on mCore.
Lovely, thank you soooo much :slight_smile:
Hello. Is it possible To use 7.4V lipo battery on the mCore board? (mBot)
Thanks for reply.
Hi slepetit,
The 7.4v lipo battery is too much for the mCore board.
According to the spec for mCore in this link, you can see the power spec for mCore is 3.7v~6V. You can use the battery in this voltage range, but normally, we use the 3.7v rechargeable lipo battery for the mBot.
MBOT Not Starting using 3.7V LiPo Battery
somewhere to buy online the mentioned-above lipo battery ?
look at this post
http://forum.makeblock.com/t/mbot-lipo-battery-performancy/6985
muchas gracias rojo. Many thanks rojo.
Pero en el link no encuentro las indicaciones para comprar una Lipo bactery . But in the link I can not find a kind of link to buy a lipo bactery.
En hora buena :wink:
No hay problema. Aquí hay unos ejemplos. ¿Que pais?
https://www.robotshop.com/en/37v-1000mah-5c-lipo-battery-makeblock-mbot.html
https://logicsacademy.com/product/rechargeable-battery-for-mbot/
Gracias. :wink:
https://www.robotshop.com/letsmakerobots/review-makeblock-mbot-bluetooth-version
"The Instruction Book says that the power supply can be from 3.7V to 6V. As I like very much LiPo batteries and the mCore board have a JST connector, I’ve started with this option. But I was not satisfied with the performance with 3.7V when I play with my custom map with overpass (see below on “having fun”), in line follower mode. The robot barely climbed the overpass. So I decided to test it with other battery options and measure the results with a multimeter, and that’s what I got: with full charged LiPo battery (3.7V) got about 3.66V delivered for the motors; with 4XAA NiHM rechargeable batteries full charged (so 4.8V), got about 4.48V delivered for the motors; with 4XAA 1.5V common batteries (so 6V), got about 4.77V delivered for the motors."
