I try to make my program better than I proposed in the topic: Need some help with hum / temp / etc. sensors.
My problem is that once the temperature exceeds, the program enters the sequence instruction and beeps 4 times (this is correct). However, 2 problems:
If the tempter changes during the 15 minutes (900 seconds), the sequence starts again immediately;
If the tempter does not change after the 15-minute sequence (900 seconds), the sequence does not resume;
Is this normal ???
