Need help w/ Starter Robot Kit!
Okaaay so:
I had an mBot which worked perfectly, played with it a long time and really liked it. A few weeks ago, I bought some parts, including a Starter Robot Kit (IR version) and a Robotic Arm Add-on. I connected the arm motor to an Adafruit motor driver to MCore and it’s okay. In the dual motor driver, I put 2 grippers.
I first tried a little code using Ir remote on starter robot kit( without ultrasonic) and it worked just fine. Then I added everything, including the arm. It doesn’t work anymore. A part of the code was written in mBlock.
Here is the code.
Can someone make this okay (viteza = speed)???
There are no visible errors. Please. RGB led strips light up. Ports okay.
And PS in original code I used # before include. and the wire, softwareserial and Arduino libraries between <> not “”. Also tried without Arduino library, same result.
Is there a weight limit for DCMotors? They were pretty slow when it worked. The robot is around 2-3 kilos now. Still, it wouldn’t have sense for the gripper motors to not work. I tried Blink and it worked. I tried a program only with motor.run(255); in loop and didn’t work.
include "MeOrion.h"
include "SoftwareSerial.h"
include "Wire.h"
include “Arduino.h”
MeInfraredReceiver ir(PORT_6);
MeDCMotor motor_right(M1);
MeDCMotor motor_left(M2);
MeDCMotor motor_claw1(PORT_1);
MeDCMotor motor_claw2(PORT_2);
MeRGBLed rgbled_4_1(4, 1, 32);
MeRGBLed rgbled_4_2(4, 2, 32);
int viteza = 150;
void setup(){
ir.begin();
void loop(){
if(ir.available()){
rgbled_4_1.setColor(0,255,255,255);
rgbled_4_1.show();
rgbled_4_2.setColor(0,0,0,255);
rgbled_4_2.show();
switch(ir.read()){
case IR_BUTTON_D:
motor_claw1.run(50);
motor_claw2.run(50);
break;
case IR_BUTTON_E:
motor_claw2.run(-50);
motor_claw1.run(-50);
break;
case IR_BUTTON_UP:
motor_right.run(viteza);
motor_left.run(viteza);
break;
case IR_BUTTON_DOWN:
motor_right.run(-viteza);
motor_left.run(-viteza);
break;
case IR_BUTTON_LEFT:
break;
case IR_BUTTON_RIGHT:
break;
case IR_BUTTON_1: viteza = 50; break;
case IR_BUTTON_2: viteza = 75; break;
case IR_BUTTON_3: viteza = 100; break;
case IR_BUTTON_4: viteza = 125; break;
case IR_BUTTON_5: viteza = 150; break;
case IR_BUTTON_6: viteza = 175; break;
case IR_BUTTON_7: viteza = 200; break;
case IR_BUTTON_8: viteza = 225; break;
case IR_BUTTON_9: viteza = 255; break;
default:
motor_left.stop();
motor_right.stop();
motor_claw1.stop();
motor_claw2.stop();
break;
@raulnastasie,
The way your loop is set up, it looks like the default in the switch statement will always happen, unless you hold down a button. The first line in the loop() is looking for input from the IR sensor, if there is no input, it will fall to the default. If you leave the default blank
default:
break;
it won’t stop. The last action should continue until you push another button is pressed.
You may want to assign button ‘*’ or ‘F’ as the stop button and perform the operations that are currently assigned to the default.
Hope this helps.
Mike
@mddickey I think you didn’t understand me. I press the buttons and nothing happens! I also tried without the if(ir.available)
