My Infrared Sensor is not recieving on regular mBot
my arduino code is not returning anything when I try to receive something. My remote is working but I don’t know how to test my reciever if it’s not returning anything. Here’s the code:
#include “MeOrion.h”
#include <SoftwareSerial.h>
//#define dumbytest 0x
MeInfraredReceiver infraredReceiverDecode(PORT_6);
//Motor
MeDCMotor motor1 (M1); //left motor
MeDCMotor motor2 (M2); //right motor
void setup()
infraredReceiverDecode.begin();
Serial.begin(9600);
void loop()
uint8_t ReceiverCode;
if(infraredReceiverDecode.available())
ReceiverCode = infraredReceiverDecode.read();
Serial.println(ReceiverCode);
// if (ReceiverCode == dumbytest) {
// motor1.run(-100);
// motor2.run(100);
delay(500);
Thank you
:bulb: Tip: To keep the forum looking nice, you can format your code like this:
```c
(Your code)
@bm476 Check a couple of things:
  • Do you have the Mentioned libraries installed in your environment (also, what IDE are you using)?
  • Verify that the pin assignment PORT_6 for MeInfraredReceiver is correct for the sensor you are using on your mBot.
Try a simple code like this one to test the sensor:
#include "MeOrion.h"
void setup() {
  Serial.begin(9600);
void loop() {
  if (infraredReceiverDecode.available()) {
    uint8_t data = infraredReceiverDecode.read();
    Serial.print("Data received: ");
    Serial.println(data, HEX);
  delay(100);
If you are coding with blocks, can you please provide a screenshot or image of your block code? Thank you!
With an mBot you should be using: #include <MeMCore.h> here not #include “MeOrion.h” ?
Hi I put the code in and got Data Received: FF which is not what I thought to expect and I tried both libraries and it didn’t work with the new code
i’m not using blocks
HOw would you find out if port 6 is the correct port because that might be the problem
I doubt that is the issue, since my code gave you a sensor reading. Try repeatedly pressing (do NOT press and hold) the remote buttons near the sensor while my code is running and see what you get.
@bm476
problem is it’s not even printing anything in the serial monitor
I don’t think it’s available…
How did it print Data Received: FF previously, then? @bm476
It only did it once
Then what happened?
Any errors?
