I have assembled and wired up the mDrawBot and currently assembled as mScara. It works - it draws from mDraw.exe. However, the lines as slightly wiggly - they are not straight. How to fix this? If I don’t get straight lines, it is useless for my application. Please advise what settings I need to look into in order to get straight lines. Thank you!
mScara - how to get straight lines
una
It may be caused by your line tense, try to adjust your belt. mDrawbot is far from any other Makeblock robot, which needs more patience to adjust. Thanks
