How do I upgrade the firmware for mDrawBot? Where do I get the latest firmware from and where do I put it in order for the mDraw.exe to find it and install it on the device?
mDrawBot upgrade
I find several files in the GIT link that you have provided. Is the firmware files in the firmwares folder? I was expecting a single firmware file there - however there are many in that folder - eggbot, scara, spider, etc. Which one is to be installed? And how do I install it?
Also, when I click the Upgrade Firmware button in mDraw.exe, which of the above firmware is upgraded?
Eggbot, scara, spider and car are all the firmware for mDrawbot, it depends on which robot you want to assemble. If you want to assemble a mScara with mDrawbot, then download the mdrawbot firmware directly.
Hi Una,
Thanks for the reply. But after downloading how do I install the firmware? Should I use mDraw to install the new firmware? How does mDraw find the newly downloaded firmware?
