Hi Makeblockers,
i just build the mCar and got some Questions:
Is it possible to send a svg graphic to the mCar and start drawing without the need for a connection to my computer?
is there a smarphone version of mDraw?
why do you got a 4 Button board on the mCar in your Video?
http://imgur.com/SAvQEAG -
there were a few errors in the assably guide:
see the diffrence how the bracket is mounted between page 24 and 25.
or that cant mount the orion/battery base like on your drawing because the holes wont line up.
By the way for all that got a problem to connect to the orion board - try to realy plug the cable hard in to the jack and if that doesent help try a diffrent cable - also i found out that one of the rj 25 cables was broken …
