mDraw with meggbot drawing stretched on Y axis
My drawbot seems to work fine in meggbot mode but the Y axis is stretched. The A motor turns more than it should and stretches the image. Is there some setting I need to adjust?
Hi dpollack,
Please make sure you have set the Microstep Resolution to HHH (pull the small white switches to H side) on both stepper motor drivers.
The motor driver settings were correct but I had the connections reversed for the A and B motors. Once I corrected that the meggbot draws fine.
Good to hear that!
