I want to use list blocks in mBlock for controling the mBot robot. What hardware (2.4G or bluetooth) do I need to do this and how do I connect the mBot to Scratch?
List blocks in mblock5
mBlock 5 doesn’t support 2.4G connection. If you use Bluetooth, a Bluetooth dongle is necessary for mBot.
Or connect PC to mBot with USB cable.
And what about mBlock 3 ?
What I want to do is, to program an mBot that can drive autonomous. But when I change to Arduino mode I can’t use the “make a List”-Block. I guess I need some kind of connection between the mBot and mBlock. Is it possible to do this via bluetooth connection with the mBoth v1.1( bluetooth version) ?
With mBlock 3, except new Bluetooth module, should support PC built-in Bluetooth connection. New bluetooth module is also labelled with V1.0_c. You can take a picture of your bluetooth module (both sides) for us.
“Make a list” only works for sprites, the stage. So I am afraid that is not working for mBot in Arduino mode though Bluetooth connected in between them.
