LED Strip Issues
In trying to do the traffic light example, I’ve been having trouble with the LED Strip.
The block is recognized in the app, but patterns connected to it don’t give any consistent results. The LED panel seems to be working fine, so it seems to be limited to the LED Strip.
Hi themacks,
Could you give details about the issue that patterns for LED Strip don’t give any consistent result?
Do you mean the LED Strip doesn’t lit up as the way you edit in the Pattern?
If yes, can we know the pattern you edit and what is the behaves on the LED strip? If it is possible, you can show us a video.
Hi themacks,
I did this activity on the IOS application. You must use the first three LEDs or the last three LEDs. You must click on the LED Strip Driver, drag the specific instruction of this block and determine which LEDs will be used.
Here is the result of Makeblock.
Hi themacks,
I made circular fire with sequence instruction.
Just send us a picture of your code.
If there is a code problem, it will be easy to find.
Exemple :
https://neuron.kynox.com/fiches/debutants/fiche-passagepietonnier
