So I am fairly new to MLaser and when I Import an image no matter what the size it will import it as only about 2.5 inches big. When I drag the image to the size I need it to be the lines become very blurry and the laser will cut two lines for every line shown. Is there a way to fix this?
Second I have noticed that when I import an image the laser will not cut the whole shape out. For example if I were to import a picture of a circle, the laser will start the cut but will end the cut a few mm away from where the cut began instead of completing the circle cut. Is there any way to fix this issue?
