Issues with larger servo
I’m using a mBot running off 4 double batteries and trying to control a servo Differnt brand but the same as this one. Whenever I try to tell it to turn to a certain degree the servo moves a few degrees then the blue light turns off, it beeps, and disconnects from bluetooth. When it reconnects it refuses to do anything with the servo but works with the wheels. The mbot RJ25 servo adapter is supposed to support up to 3 amps, and this motor should only draw somewhere between 1 and 2 at peak. Any idea what’s causing this? The included 9g servo works fine, it’s just the larger servo having issues.
