I have just bought my new MBlock Starter Kit, run a simple program, but neither remote or ultrasonic sensor not responding.
I can only do turns, run forward and backward… nothing else
What is the issue?
What is the issue?
Based on the code you posted, there is no issue. Your program does not include code to use the ultrasonic sensor. Also you are only using the LEFT and RIGHT buttons from the remote.
Keep in mind that ONLY one program loaded at a time, the default program, or any previous programs that you write, will not be available when you upload a new program.
Hope this helps.
Mike
Hi Vinci,
Also, here is a program online course for mBot which can help when program for mBot:http://learn.makeblock.com/en/mbot-programming/
@tec_support you are the first one to post anything for the ultra sonic sensor that works. They need to give you a rise. Others need more training.
