Hi all,
I have bought two robots: one mbot and one starter kit.
I have noted two main differences and I’d like to know if they are a malfunction or not on starter kit.
Starter kit has a buzzer but I was not able to produce any sound notes (short music) using the IPAD application,
but mbot can. It is a problem of the board or is it normal ? If normal does it exists a Makeblock speaker that I may add? -
Yesterday, while testing the robot I had two times the problem “Unrecognized Firmware” and I have solved upgrading the firmware. Should I need to repair/substitute the board or it is “quite” normal? Now the board is running but I think that the issue may happen again. Both times the “Unrecognized Firmware” message happened while trying to use the Android app but I do not know if it is a random event or there is a connection. Once it fails, also on IPAD I have received the error message.
Last question: when upgrading firmware I have seen that is mandatory to turn off the buzzer (mandatory or suggested?), but the board must be or not turned on attached to the battery pack; plugging the USB cable to the PC the board seems active but I have not understood what is the recommendation for the power button.
Thank in advance for the support.
Maurizio
