How to control arduino using mblock and bluetooth?
I want to control arudino using mblock and bluetooth shield HC-05?
Assuming that mblock can control arduino using bluetooth module, I tried few things without success. I am not sure if my bluetooh setup is problem or mBlock is not able to recognize the COM port provided by bluetooth.
I can see the COM device (in fact two??) when I pair HC-05 with PC. I have following questions based on whatever I have tried so far.
  • When I connect HC-05, should I connect Tx to Tx OR reverse them?
    • There are varying articles describing both ways of connection.
  • How much baud rate do I need to set on the bluetooth device?
  • Do I need to use the voltage divider for Rx? Again there are varying tutorials.
  • Is mblock default arduino firmware sufficient for such a setup?
  • what should be the baud rate set for mblock?
Thanks,
Manish
Hi Manish,
In theory, the answer is Yes. In practice, it will take some work on your part. mBlock communicates to an Arduino using the Firmata protocol. I have not done this but I believe these are the steps you should take (generally in order):
  • Find a version of Firmata that communicates using Bluetooth. The Arduino IDE comes with an example StandardFirmataBLE. I don’t know if that works with an HC-05 shield. Also remember that you will need two GPIO pins to communicate with the HC-05. This means that you should NOT use those pins with mBlock. Your Arduino TX is connected to the RX of the HC-05. The baud rate is automatically set to 56700 by the Firmata code.
  • If you’re using Windows, pair your computer with your HC-05. This creates two COM ports, one for outgoing connections and another for incoming connections. You will want to use the outgoing COM port. If I recall correctly, you can use the Device Manager to figure out which is which. Sorry but I can’t help with Mac OS or Linux.
  • In mBlock, connect to the outgoing COM port. mBlock should now connect with your Arduino.
Good luck,
Aram
Hi Aram,
Thank you for the inputs. After toying around things for some time, I could make mBlock control Arduino using Bluetooth. Following are details.
Control Aduino using mBlock with Bluetooth
  • Set the bluetooth baud rate to 115200. The mBlock firmware uses
    this baud rate for serial communication.
  • Connect Bluetooth to Rx and Tx of Arduino.
  • Upload default Arduino firmware (orion firmware) to
    Arudino using mBlock.
  • Use mBlock to interact with Arduino using Bluetooth.
    • Please note that Bluetooth cannot be used to upload
      the sketches to Arduino for offline mode.
Connecting Bluetooth COM device to PC in AT mode to set baud rate.
  • Upload empty (default) sketch to arudino using USB cable.
  • Connect 5V of BT shield to 3.3V of arduino.
  • Connect EN or BT to 5V.
  • Connect Tx to Tx and Rx to Rx.
  • Use USB cable to power on arudino.
  • Before turning the power ON, keep pressing the EN
    button on BT shield. The LED should blink with almost
    a second delay. That is the indication that it is AT mode.
  • Start Arduino IDE, and connect to the COM port of arudino
    and NOT that of the BT.
  • Start serial monitor.
  • Set the baud to 38400 and terminate character settings to
    "Both NL $ CR".
  • In the command of serial monitor type at twice. First time response
    will be error, second time it should be ok.
  • Now use the at commands to set baud rate using “at +uart=115200,0,0” e.g.
  • Use “at +uart?” to see what is the baud rate set on the device.
Connect Bluetooth device to Rx and Tx of Arduino.
Arudino <-> HC - 05
5V Vcc
GND GND
Rx Tx
Tx Rx (Via Voltage divider)
Some of the articles talk about connecting 3.3V of Arduino to the
Vcc of HC-05 and not using the voltage divider at all. However this
combination fails as once increases the buad rate.
Check out more details about voltage divider here. https://electronics.stackexchange.com/questions/280500/why-do-you-have-to-use-a-voltage-divider-with-hc-05-bluetooth-module-arduino
What is the story of two COM devices for Bluetooth?
Thanks,
Manish
Hi, msapariya
could you please give me your email address because want to ask you some questions relating bluetooth?
thanks in advance
