I do not fully understand the : Edit Pattern.
Ok for Static but the other terms.
Can someone explain to me the differences?
Hi Crackel,
You can edit lit up three LEDs with three different colors, then try the Roll, Repeat, Marquee, BLN and you will find the different effects with these settings.
As for the Gradient, you need two nodes to set different patterns, then the other node controls the setted two patterns, to see the gradient changing between the two patterns.
