CyberpPi - What's the Structure of Message for LAN Broadcast (ESP NOW)
Hi, I’d like to communicate an ESP-32 with a CyberPI.
It says in the documentation that the Cyperpi’s LAN Broadcast is managed with ESP-NOW:
“LAN commnunication between CyberPis is implemented based on the ESP-NOW protocol pf ESP32”
(https://education.makeblock.com/help/faqs-on-product-specifications/)
But ESP-NOW requires the message structure to be able to send a message to the Cyberpi.
My question is: what is the ESP NOW message structure for Cyberpi?
Because I don’t think it’s a good one:
typedef struct struct_message {
char a[32];
int b;
float c;
string d;
bool e;
} struct_message;
Yours faithfully
Illyes
You could try something like this:
typedef struct {
    char text[32];      // Replace 'string' with a character array
    int sensorValue;    // Example: Integer field for sensor readings
    float temperature;  // Example: Floating-point field for temperature
    bool flag;          // Example: Boolean field for status
} esp_now_message;
But to be honest, I’m a web dev and backend guy; I don’t know much about this type of stuff.
Perhaps you can ask makeblock support via email (support@makeblock.com).
Good luck!
@Illyes
