Controlling CyberPi display pixelwise
I am just starting with mblock and the CyberPi. With the Display+ extension, it is possible to kind of draw on the display using doodles. However, this is a very indirect way of control - is there any way (probably from microPython, I have not seen any relevant blocks) to directly draw on the display, e.g. something like “cyberpi.display.set(pixel_x, pixel_y, r, g, b)”? I have found nothing in the API of cyberpi itself or the Display+ API, but I suspect there must be some undocumented way to do this, since it is what the Display+ cyberpi.sketch.* methods must be doing internally.
There currently is not. I may make an extension related to what you are talking about, though.
Thanks a lot! Just out of curiosity: Is the source of Display+ available somewhere? I was not able to find it, but if I was to write such an extension myself, the source of Display+ would of course be super helpful as a starting point.
Yes. I will private message it to you.
Awesome, thanks :smile:
I messaged you. Did you see it?
