Code does not upload to mCore
I downloaded the mBlock new version(V4.0.4). I wrote the following code block and tried to upload to mCore. I waited it to load but it did not upload to mCore.
It worked before when using in previous versions of mBlock.
Do you have any idea?
Hi gungorhilal,
What is the operating system of your computer?
I am using the windows operating system. (windows 10, 64-bit processor)
Hi gungorhilal,
Here we tested it on Windows 10 computer and there is no problem uploading program to mBot.
How about totally uninstall the mBlock software and re install have a try.
Hi tec_support,
Thanks for reply.
I re-installed the mBlock program. I think there are some problems in this version.
I uploaded the first code, and it works. When I want to load a different code, it gives you a warning as you see in the picture. I waited 5-10 mins and tried to upload again and it works. Sometimes the program gives that warning, but sometimes it works.
Thanks again:slight_smile:
Do you have a block somewhere (maybe in another sprite) which is not possible in Arduino mode? Try again to start from a blank program.
Hi Andreas,
I tried it many times and don’t have another sprite/block.
Thank you for your suggestions.
