Code arduino mcar 2 stepper and 1 servo
Hi
I realized that I can’t send code to my MCAR with Mdraw, I must stay conected to my PC.
Have you an little Arduino code for MCAR has to make just rectangle?
I would like an example of a code for beginer
Think,
Sorry for my english
Hi Cath_Heyman,
This is normal, the must be a connection between mDraw and mCar when you upgrade firmware for mCar or Draw a image with it.
For Guidance about how to use mCar, please download in this link: http://learn.makeblock.com/en/mdrawbot-kit/
Hi Tec,
But we can not send the code in the memory of the MeOrion, from MDraw.exe, for MCAR is not connected to the PC?
Hi Cath_Heyman,
mDrawbot doesn’t have this function.
Hola, tengo el mismo problema ¿has conseguido que mCar funcione de manera autonoma? ¿tienes algun programa?
Gracias
Hello, I have the same problem did you get to work autonomously mac? Do you have a program?
Thank you
jhilario
Hello JHilario,
I make arduino code for make rectangle, in autonomously.
#include “MeOrion.h”
#include <SoftwareSerial.h>
MeStepper stepper1(PORT_1);
MeStepper stepper2(PORT_2);
// 1 tour =3200
// diametre roue =64 => Circ: 201.06
// entre axe roue = 130mm circ 130 = 408.4
// Longueur arc: 102.1 a 90° ( 408.4/360*90)
// 1 pas:201.06/3200=0.0628 mm
// nombre de pas pour 90° 102.1/0.0628=1625.82 pas
// variables
int turnSteps = -1630; // nombre de pas pour 90° 1616 91°
int lineSteps = -2500; //nombre de pas pour avanver
int stepperSpeed = 1000; //speed of the stepper (steps per second)
int steps1 = 0; // garder une trace du nombre de pas pour le moteur 1
int steps2 = 0; // garder une trace du nombre de pas pour le moteur 2
boolean turn1 = false; //trace si tourner ou avancer pour le moteur 1
boolean turn2 = false; //trace si tourner ou avancer pour le moteur 2
void setup()
delay(1000); //temps demarer robot apres alim
stepper1.setMaxSpeed(1000);
stepper1.setAcceleration(20000);
stepper1.move(1); // j’ai pas compris mais indispensable
stepper1.setSpeed(stepperSpeed);
stepper2.setMaxSpeed(1000);
stepper2.setAcceleration(20000);
stepper2.move(-1); // j’ai pas compris mais indispensable
stepper2.setSpeed(stepperSpeed);
void loop() {
if (steps1 == 0) {
int target = 0;
if (turn1 == true) {
target = turnSteps;
else {
  target = lineSteps;
stepper1.move(target);
turn1 = !turn1;
if (steps2 == 0) {
int target = 0;
if (turn2 == true) {
target = turnSteps;
else {
  target = -lineSteps;
stepper2.move(target);
turn2 = !turn2;
steps1 = stepper1.distanceToGo();
steps2 = stepper2.distanceToGo();
stepper1.runSpeedToPosition();
stepper2.runSpeedToPosition();
Hello, thank you very much for the code, I’ll try it and if I can I will adapt. It looks very good.
So far I have gotten it to work autonomously using mDraw by the bluetooth module in the Port_5. Here you have a home video mCar and bluetooth
Thank you
Hola, muchas gracias por el código, lo probaré y si puedo lo adaptaré. Parece muy bueno.
De momento he conseguido que funcione de manera autónoma usando mDraw mediante el módulo bluetooth en el Port_5.
Gracias
