Caterpillar with Ultrasonic Sensor
The obstacle avoidance car was controlled by Arduino with an ultrasonic sensor and powered by6 pcs of 1.5V AA battery.
I’d love to see how the 6xAA battery holder was mounted - only because I’m finding it tricky to work out how to actually mount my own properly (without batteries almost springing out because of bolts pressed against them)
Try to go through this pdf and see if it helps.
Short answer - use plastic rivets to connect the battery holder to the acrylic base (mine seems more like fibreboard actually) rather than bolts…
Andrew
What’s weird is using the rivets to connect the battery holder to the plastic, feels really flimsy. It just takes a small knock for the rivets to become lose…
The big lugs worked well for the battery holder, but the small lugs for the arduino were hopeless. I used some sticky-backed foam tape to adhere the board to the plastic plate, which worked well. .
I’ve mounted my battery compartment underneath the cross strut in the caterpillar design, with the arduino mounted on top, complete with shield on top. I had to use the L brackets to do this. It works, but could be refined a bit.
Hth, Remy
You need to peel off the paper backing used when the board is laser cut, Andy. It’s there to stop the plastic getting marked but should peel off okay.
https://www.evernote.com/shard/s2/sh/a5babd9f-79db-4463-b798-a697e245c66f/df14602b5fb16cfd4ec5fcc4598199b0/deep/0/Screenshot%2022/06/2013%2015:59.png
Hopefully that makes sense? I tweeted you a link to the tape I used to affix my arduino to the board. Something like this:
http://www.amazon.co.uk/BRAND-NEW-DOUBLE-PROJECT-MOUNTING/dp/B00AWOTM4E/ref=pd_sim_sbs_diy_10
(although I couldn’t say if it was exactly that tape, any double-sided sticky pads would do). Same would work for the battery compartment.
The benefit of suspending the batteries under the main cross-strut is you leave the top free to mount the arduino itself, and also lower the centre of gravity I guess?
Profile picture to illustrate no real loss of clearance:
https://www.evernote.com/shard/s2/sh/7bacb6c6-2d91-4972-a8b7-77deeffc1bde/69d07092723fee3a333b2632e7df5112/deep/0/Screenshot%2022/06/2013%2016:04.png
