Can't reset firmware-RANGER
I have MBlock5 on my PC, I want to reset the firmware to factory settings but I just can’t find a way to do it on MBlock5. I can’t connect to Ranger via Bluetooth on my phone either because meAuriga has code we created. How do I reset the firmware?FirmwareFailed
NDefaultFirmware
Just to understand - you can connect ranger to the PC and upload your own code, but when you try to upload the firmware it fails? (just establishing that you have a working cable and using the correct serial port)
Depending on how far you want to go, you could install Arduino and upload the standard firmware in the examples code. I can explain how to do that if it’s the way you want to go, but as far as MBlock goes, I haven’t experienced this issue.
