Bluetooth instruction?
Hi every one, I want to write a program to control the mbot via an external device all code in Javascript.
I can connect my computer to the mbot but i don’t know what to send ? Is there somewhere a kind of manual for this communication. In other words, what is the bluetooth api ? What kind of hexadecimals message that i should send ?
Regards
This is the source for the mbot’s firmware, search for bluetooth and around line 210 you should see what they are sending. (This is my 2 minute stab at finding where the commands are.) It looks like they just switch serial to bluetooth and send the same commands as if the mbot was plugged into usb.
Thank you but it don’t correspond to my use case. In fact, I want to control the mbot via Myo and for that i will use a Node program that will send bluetooth instructions to the mBot. That’s why I need to have the precise instructions to send to MBots
But i like your idea and maybe i will try it
Regards
