Bluetooth Adapter doesn't work?
I bought MakeBlock Bluetooth Adapter. I plugged it into a desktop computer running Windows 10 with latest updates. The computer doesn’t have Bluetooth onboard. I tried to connect CyberPi and MegaPi to Bluetooth but I don’t see Bluetooth connection on mBlock software. I can pair successfully to both boards. I followed the instructions at Mbot with mblock5 bluetooth on windows 10 broken for “live” mode and it didn’t work. How can I fix the problem?
If you mean this Bluetooth Adapter:
Then you should be able to use it fine by plugging it into your device. Click on the device connection menu, then connect to your Bluetooth Dongle on the port you have plugged it into. Make sure you check the “Show all devices” box to find it.
Pair it with your mBot and upload the code.
Bluetooth problem
I was confused. I was trying to connect using Bluetooth, not USB. It worked when I connected using USB port. I can upload code to CyberPI board but not MegaPi board.
Is that why third-party Bluetooth adapters don’t work with MakeBlock robots?
Yes, it is
I’m glad you got everything figured out and working. :slight_smile:
