The problem is,Benbox is able to recognize the board and upload it’s firmware,motors do move and draw but the laser does not turn on when I use Benbox…When I unplug the orange plug from the port the light that the port is active lights up,but when I plug the orange plug back in it just turns off and laser does not run.The laser powers on and engraves with no problem when I use mDraw but with Benbox it refuses to turn on.Could it be due to my Orion board malfunctioning?The laser I currently got is just a fresh replacement as previous one was completly broken.It is the official XY Plotter laser upgrade pack.
Benbox doesn't seem to like my laser on XY Plotter
tech_support
Hi Bleky,
Please check the following note and switch the order of the two wires coming from laser have a try.
Gundelputz
Interchange the connections of the laser. The polarity is reversed as opposed to MDraw. Property with me the problem solved with a double switch.
reangeorge
well, it works great.
Let me know you still have issues… email me: gf@EnduranceRobots.com
