Bad mistake in Arduino library
I just tried to write individual programs using mDrawBot Kit with mBlock.
Nothing worked like it should. Analysing the generated Arduino Code I found that there is a Mistake in one of the libraries.
When I, in mBlock, insert the Block "Set Delta to atan of x/y"
it will, in Arduino Code, translate to delta = atan(angle_rad*(y) / (x));
But it should translate to delta = angle_rad*(atan(y) / (x));
I get the same issue using acos and asin functions. Fixing is only possible over the Arduino IDE.
As this is very inconvenient I hope you find a way to update the library.
Regards
Reinhard
Hi @atz,
I’d say it is more likely an error in the code generator (which is responsible for generating the C code for the Arduino environment). Regardless, it does need to be corrected. What version of mBlock are you using and on which operating system? This is information that @tec_support will need to help you.
Best regards,
Chuck
Hi Chuck,
I am using the Windows 3.4.8 Version of mBlock and the 3.4.3 Version on Mac. The mistake is the same.
But I myself made a mistake:
“set a to atan of b” should translate to
a=atan(b); if you want the result in radians and
a=angle_deg*atan(b); if you want the result in degrees.
Meanwhile I also found a workaround in Scratch:
“set a to atan of (b/angle_rad)” or “set a to angle_deg*atan(b/angle_rad)” if you want degrees.
Best regards
Reinhard
Good to hear that you found a workaround, but it’s still a bug in the code generator. Have you tried mBlock 4.0 to see if it still persists?
I tried the function on mBlock 4.01 on my Mac. It is still the same.
Hi atz,
We have provided feedback of this issue to our engineer.
Thanks for your feedback!
not to be a pain but atan is still wrong in arduino mode
it still says:
delta = atan((4)*angle_deg / (2));
while it should be:
delta = atan((4/2))*angle_deg;
maybe usefull to correct it
hello
my name is hans.
