Although mLaser works on Mac, I found it completely useless…till now!!!
Finally I encountered a method with excellent results using Mac. It also works in PC. It’s relatively easy and there are no errors.
Steps 1 to 5 can be made in Mac, PC, Linux, Android…etc.
1—Make the drawing in any CAD program in the positive quadrant.
2—Export DXF file of the area to cut
3—In any web browser open https://cnc-apps.com/en/app/dxf2gcode.This free app will convert the DXF file into GCODE.
Load the DXF and select Plasma cutting Type
Convert & generate the output file whose extension will be EIA.
4—Post-process the EIA file with https://cnc-apps.com/en/app/replaceingcode. Paste in the replacement commands window this suggestion
G21=M4 P0
G90=
G00=G00 F2000
G01=G01 F300
M15=M4 P222
M16=M4 P0
You may play with the F and P values according to the type of media and the desired results.
5.Generate the output file and rename the EIA extension into GCODE
6 In mLaser choose GCODE mode and load this file. Finish will initiate the Mlaser cut.
7 If the final render dimensions are not suitable you may scale the GCODE file using https://cnc-apps.com/en/app/scale_part
8 There are many other free tools to play with in https://cnc-apps.com/en/
Any suggestions please let me know.
Cheers
