Temperature range for materials?
What is (roughly) the stable temperature range for the makeblock parts? Most of the parts are solid alu and should be fine up until 660 degrees, but how about the rubber-tank-tracks and the timing belts?
I ask this because I am wondering if I could experiment with small conveyor-belts/moving platforms through ovens and/or under hot-lamps.
I think rubber-tank-tracks and the timing belts can’t hold the ovens… The temperature is too high to it. We are planning to list our gear right now. You can build gear driver for you moving platforms.
