Rod ends
It is Rod ends ,joint bearing is a spherical plain bearing.It Can bear radial load, axial load or along the radial, axial union load.we always used for low speed swinging movement, also can be in a certain Angle range for tilting movement.This Rod ends hole is 4 mm for better used in Makeblock.
