Problem with servo motor
Hi
I start learning mblock for controlling the servo motor.After I press the green flag,the servo motor do not rotate. But when I use the sweep example from the arduino software,it has no problem on rotating.
To run mBlock program online, you may need upgrade firmware for your main board with mBlock software first.
I upgrade the firmware but it still doesn’t work
According to this video https://www.youtube.com/watch?v=Ay70mHig4yE you may try upload code to mbot board and servo should work.
Have the same problem. Servo works fine, if I use Arduino with ME uno shield (code uploaded directly to UNO board). When I connect servo to mbot and use bluetooth control via smartphone, it doesnt work properly.
