Mblock wait() function is not accurate
#21
I have taken the new user tutorial.
I did hit a post limit once…
For some reason, upload mode works/…
Will try your code…
THanks!
Any other suggestions?
#22
Great!
If the code doesn’t work, mention me as @Best_codes. Also, first try changing the values of both the onboard gyro sensor blocks to y-axis or z-axis. If it still fails, try doing [block] - degrees instead of +.
As a last resort, change it all back and use turn left in the custom block instead. I will test the block tomorrow, and send you the mBlock project.
Hope that keeps you busy, and have a nice rest of your day / night? Hmm… @V205
#23
Night here for your info :slight_smile:
Well thank you!
I will tinker with that project today…
#24
OK, have a great rest of your night! (me too, so I better some rest soon. :confused:)
#25
hmmm.
It does not work…
Probably a bug.
Have a great night :slight_smile:
#26
Sorry, I will fix it tomorrow when I can test with my Ranger (if I have time).
#27
Thanks! :slight_smile:
No worries :slight_smile:
#28
Here, I tested this, I’ll get you the file later:
#29
File here @V205:
https://drive.internxt.com/sh/file/4e47bb8e-5c63-4e02-a9de-ebaf7039f564/04f56b6079c4618681c6bf8a24e189b4732a53b998be2b816fe14e7c67491304
#30
I have not downloaded the file yet.
That is using a CyberPi(using ranger here…)?
#31
Yes, the file I gave has the Ranger version @V205.
#32
Could I have a photo of the ranger version?
Don’t really want to download(no preview……)
Thanks
#33
Sure! Sorry about that.
@V205
#34
Ok thanks!
Will try it out later.
BTW, do you know how to take the plastic cover off the ranger’s auriga?
Thanks
#35
Yes. You can just pull it apart if you are careful. It is snap together., if I remember correctly. @V205
#36
No screws?
Ok Thanks!
#37
No problem! Be careful with it, though. You don’t want to mess up the wrong things. :grimacing:
#38
I haven’t got round to building Nervous Bird yet - but as far as I could tell, the balancing routines for MegaPi were built in to the default firmware for the board.
The following may be of some value:
#39
Thanks for the info @CommandeR. Did you mean to post this here:
