Makeblock Megapi Encoder/DC Motor Driver 1.0 pin translation
Can i get the pin names that would correspond to this encoder?
https://www.robotshop.com/en/lynxmotion-12v-90-rpm-9911oz-in-1269-brushed-dc-gear-motor-w--encoder.html
MegaPi Encoder Pins
Hi 3ALARM,
I have sent the schematic of the driver to your email for reference, hope it helps.
so Is Bo1 and Bo2 correspond with Motor + and Motor - ?
With 12 volt power supplied i am reading 12v out of those two pins.
5volts out of 3 and 4
and just a trace out of Net1 Net 2 so those are the Hall Sensors?
thanks for your help!
Kevin Leeser
Hi 3ALARM,
Here is the information of Makeblock Megapi Encoder that we can only offer:
http://store.makeblock.com/megapi-encoder-dc-motor-driver
As you wanna use it together with non-makeblock product, I am afraid you have to explore and test by yourself.
Hi
can you send me the schematic of the driver too?
Thanks
Michael
Hi MichaelT,
Already sent you the schematic of makeblock Megapi Encoder/DC motor driver via email again.
Sorry I did not receive any mail from makeblock.
Can you send it again?
Michael
Hi MichaelT,
We sent it to 3alarm@ameritech.net and sent it again.
Hi Tech Support
I am MichaelT and not 3ALARM. Because of that I have a different mail address.
Michael
Hi MichaelT,
Sorry, I put the wrong email address. Sent you now.
Just received it - thanks.
Hey Micheal T, what are you trying to do? i am just trying to wire up an encoder, and whille i can get it to spin, with the Motor +/- leads, i get not encoder info or spead control, and the driver sheild gets quite hot, already blew one up. Any assistance advice is welcome!
Cheers
Kevin
Hi 3ALARM
I want to connect the motor to a different driver (not from MakeBlock) and want to have some info about the motor and the wiring. MakeBlock seems not to have much info (see http://forum.makeblock.com/t/information-about-25mm-dc-encoder-motor/10791. So I tried to gather every little piece I can get.
Michael
#14
me too,
i have this guy from robot shop
And it just heats up the megaPi driver sheild no matter how i hook it up.
i did have luck running it with some AdaFruit motor driver v2.3 and a regular uno though.
a link to that adventure is over here
https://forums.adafruit.com/viewtopic.php?f=31&t=135740&p=673306#p673306
#15
