I have encountered the following problems with the following code, which is adapted from the sample code in makeblock library.
- The For loop does not work: motor only ran once.
- The following code was not executed:
stepper_x.move(7000);
stepper_x.run();
#include “MeMegaPi.h”
#include <SoftwareSerial.h>
MeStepperOnBoard stepper_x(SLOT_4);
void setup()
Serial.begin(9600);
// Change these to suit your stepper if you want
stepper_x.setMaxSpeed(500);
stepper_x.setAcceleration(20000);
stepper_x.setMicroStep(16);
stepper_x.enableOutputs();
void loop()
if(Serial.available())
char a = Serial.read();
switch(a)
case ‘0’:
for (int i=0; i <= 5; i++){
stepper_x.run();
stepper_x.move(-7000);
stepper_x.run();
break;
stepper_x.run();
