I want to add an upload mode broadcast extension to my device
#21
Yes, I’m checking with other Nano-old devices but all same symptom.
I’ve checked with mblock published device “Arduino Nano (old)” : Developers : Ablock
then uploading works well with my Nano-old devices.
So, I guess if I change the vendor id in “Connection Settings” , it will probably work.
This is why I asked @xuanngoc the vendor id of Nano-old.
And the test code I’m using is very short.
It’s only for upload test.
Best Regards,
#22
@gosteamlib I don’t know if the vendor ID would be the issue in this case, but you can try it. :slight_smile: I don’t have any other ideas right now.
#23
Or, is there any other differences between making Nano and Nano-old ?
Best Regards,
#24
Yes, there is. They have different drivers.
#25
Yes, I know that as well.
So I want the know what settings should be different between two devices to make it work.
The settings means as below.
I think @xuanngoc already knows the answer, and I’m waiting for his or her advice.
Best Regards,
#26
I am not sure, I do not have access to both device sources yet. I’ll private message them to you later.
#27
Hi @gosteamlib, I made no Extensions or Devices for Arduino Nano.
Luckily I have both two boards Nano and Nano-Old. I tried to use Device Arduino Nano (old) to upload to my Nano-Old board, it is working normally.
But if I use Device Arduino Nano (old) to upload to Nano board (Not the old version), I get the same error as you.
I think you should try Device Arduino Nano
Best regard!
#28
I haven’t tried this yet, but I will. I think @gosteamlib found some useful resources to help him already, though. Thanks!
#29
Hi @Best_codes, my Extension (Upload Mode) has been approved. But it seems doesn’t work like Upload Mode (dev: block official).
Here is my extension, I just changed the name and the version then submitted it for review.
arduino_broadcast_2_v1.0.3_f7cd95f0.zip (74.1 KB)
I just want to send data from my custom device to control Sprite Panda
Thank you for your time! :smiley:
#30
Sorry, I will check out the extension and see if I can find the issue.
#31
@Best_codes, Is there a way to add my Device to the extension Upload Mode (Mblock Official) like this?
#32
No, unless you can get mBlock to manually do it for you @xuanngoc.
