Help me please to correctly run on linux mblock
when you start the application, you receive this error:
Screenshot_20180205_175426
After the application runs, everything works except the upload on the arduino.
Tried to reinstall mblock. Installed it on another computer. The effect is the same. What am I doing wrong ?
Hi anonim332,
What is the particular system of your linux computer?
After you install the mBlock software, have you installed the plug-in?
Besides, please make sure you are using the correct board and serial port for the makeblock robot or mainboard.
System configuration:
Screenshot_20180206_144305
video of the problem:
https://yadi.sk/i/EoHV7sZU3S9CUv
Hi anonim332,
What is the board do you have? If it is mCore or Me Orion board, you need choose the mBot (mCore ) or Starter/Ultimate (Orion) instead of Arduino uno.
If it is not Makeblock mainboard, but the Arduino uno, it is true that mBlock 4.x doesn’t support uploading program to Arduino.
Hi tec_support,
Support for uploads program in Arduino will not be renewed?
Hi anonim332,
Yes, the mBlock 4.x is experimental version, currently there is no plan to update it.
