HELP Can't find example code on GITHUB
Hi I have a robot starter kit, and I have downloaded the example libraries here https://github.com/Makeblock-official/Makeblock-Libraries
I have tried to follow this tutorial but on that github there are NO examples code for the starter kit.
Hi Fabio,
Which version Starter robot you have? Bluetooth version or IR version?
The Starter robot support mBlock program, you can reset default program for the starter robot, then play the robot with IR remote controller (IR Version) or Makeblock APP via Bluetooth connection (Bluetooth Version).
You can also upgrade firmware for Starter and program for the Starter online with the mBlock software.
Here is our learn website where provide all the instructions for Starter robot.
And here are some FAQ instructions for Starter which will be very useful for you.
I found the code, I was able to.use Arduino IDE to.develop some sketches. It worked like.a.charm for.a.while but now, when I update a script it gives me an avrdude error. I think mthe bootloader just died non me. This should not happen.
Hi Fabio
In this case, please kindly refer to the document in this post to double check if the Me Orion board lose bootloader.
You can send us the error message after you tested it.
Btw, do you have other Arduino board like Arduino uno, or Me Orion, mCore which works okay?
